cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
Tarv
Mar 08, 2014Aspirant
My results going from stock E2160 to E7600 ($30 on eBay). I had already been running 8GB RAM, 8192 MB [6-6-6-18 DDR2]. Also I'm running 6x3TB drives all at 5400RPM.
BEFORE:
AFTER:
BEFORE:
TheNAS:~# cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 15
model name : Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz
stepping : 13
cpu MHz : 1795.524
cache size : 1024 KB
TheNAS:~# hdparm -t -T /dev/c/c
/dev/c/c:
Timing cached reads: 2306 MB in 2.00 seconds = 1152.98 MB/sec
Timing buffered disk reads: 1144 MB in 3.00 seconds = 381.03 MB/sec
Fan SYS 1607 RPM
Fan CPU 1896 RPM
Temp SYS 57 C / 134 F [Normal 0-65 C / 32-149 F]
Temp CPU 26.5 C / 79 F [Normal 0-85 C / 32-185 F]
AFTER:
processor : 0
cpu family : 6
model : 23
model name : Intel(R) Core(TM)2 Duo CPU E7600 @ 3.06GHz
stepping : 10
cpu MHz : 3059.349
cache size : 3072 KB
/dev/c/c:
Timing cached reads: 3880 MB in 2.00 seconds = 1940.38 MB/sec
Timing buffered disk reads: 970 MB in 3.00 seconds = 323.05 MB/sec
Fan SYS 1088 RPM
Fan CPU 2008 RPM
Temp SYS 61 C / 141 F [Normal 0-65 C / 32-149 F]
Temp CPU 28.5 C / 83 F [Normal 0-85 C / 32-185 F]
