cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
dhl
Mar 21, 2014Luminary
Just upgraded my partners' Pro system in LA and again seeing great results! :D
We used another E6700 SL9ZF purchased on eBay:
BEFORE CPU:
AFTER CPU:
BEFORE - timed reads (best of 10)
AFTER - timed reads (best of 10)
BEFORE - temperatures and fans
AFTER - temperatures and fans
I think the team will be very happy with this upgrade, especially for things like large iPhoto libraries.
Once again, super easy to do and will give our Pro years of new life! :thumbsup:
BEFORE CPU:
PM_ReadyNAS:/Public_Matters# cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 15
model name : Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz
stepping : 13
cpu MHz : 1795.801
cache size : 1024 KB
AFTER CPU:
PM_ReadyNAS:/Public_Matters# cat /proc/cpuinfo processor : 0
cpu family : 6
model : 15
model name : Intel(R) Core(TM)2 CPU 6700 @ 2.66GHz
stepping : 6
cpu MHz : 2660.099
cache size : 4096 KB
PM_ReadyNAS:/Public_Matters# hdparm -t -T /dev/c/c
/dev/c/c:
Timing cached reads: 2428 MB in 2.00 seconds = 1214.01 MB/sec
Timing buffered disk reads: 864 MB in 3.00 seconds = 287.72 MB/sec
/dev/c/c:
Timing cached reads: 10142 MB in 2.00 seconds = 5080.49 MB/sec
Timing buffered disk reads: 814 MB in 3.00 seconds = 271.29 MB/sec
Fan SYS 937 RPM OK
Fan CPU 1721 RPM OK
Temp SYS 58 C / 136 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 21.5 C / 70 F [Normal 0-85 C / 32-185 F] OK
Fan SYS 932 RPM OK
Fan CPU 2083 RPM OK
Temp CPU 22.5 C / 72 F [Normal 0-85 C / 32-185 F] OK
