cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
dhl
Nov 10, 2014Luminary
fastfwd wrote:
Yes and yes. The Patriot PSD28G800K kit (2 x 4GB) works well.
I just upgraded to this RAM kit which I bought used on Ebay. Not seeing any change in performance but that may be on my drives at this point. Will find out soon since they're overdue for replacement.
I did a memory test from the boot menu and was wondering how to interpret the results. It did two passes. First one that passed, then a second. At 100% the second time, it also said Pass. But it stayed at 100% and didn't loop a third time. After about a half hour I had to power off to get out of memory test mode.
I've never run the mem test before and am wondering if this is normal behavior. Is it suppose to work like this? Does this mean my memory is good?
Thanks!
