cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
mdgm-ntgr
Nov 10, 2014NETGEAR Employee Retired
Do you have a backup?
You could try using the NAS unit for a while, download the logs and check diagnostics.log
