cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
dhl
Nov 10, 2014Luminary
Backups are to two USB drives. Each drive backs up different shares. One is connected to the ReadyNAS and backs up via FrontView. The other attaches to my desktop and backs up via Carbon Copy Cloner.
Here's the SMART data for the raid set. Some of the disks have Raw Read Errors but they check out as OK with SMART
The problem last time was with the USB drive connected to the ReadyNAS.
viewtopic.php?f=31&t=78258
I'm having trouble with this drive again so maybe it's really starting to go? I can try running fsck on it again and see what it says.
I'm still concerned about the RAM and will send it back if it's bad. I downloaded the logs and it checks out:
Thoughts?
SMART Information for Disk 1
Model: SAMSUNG HD203WI
Serial: S1UYJ1KZ310344
Firmware: 1AN10002
SMART Attribute
Raw Read Error Rate 159
Throughput Performance 0
Spin Up Time 6186
Start Stop Count 46
Reallocated Sector Count 0
Seek Error Rate 0
Seek Time Performance 0
Power On Hours 39601
Spin Retry Count 0
Calibration Retry Count 0
Power Cycle Count 46
G-Sense Error Rate 1
Power-Off Retract Count 0
Temperature Celsius 36
Hardware ECC Recovered 0
Reallocated Event Count 0
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Multi Zone Error Rate 0
Load Retry Count 0
Load Cycle Count 63
ATA Error Count 0
SMART Information for Disk 3
Serial: S1UYJ1KZ310364
Firmware: 1AN10002
SMART Attribute
Raw Read Error Rate 589
Spin Up Time 6146
Start Stop Count 46
Seek Error Rate 0
Spin Retry Count 0
G-Sense Error Rate 3
Temperature Celsius 34
Load Retry Count 0
Load Cycle Count 62
ATA Error Count 0
SMART Information for Disk 4
Serial: S1UYJ1KZ310345
Firmware: 1AN10002
SMART Attribute
Raw Read Error Rate 163
Spin Up Time 6289
Start Stop Count 46
Seek Error Rate 0
Spin Retry Count 0
G-Sense Error Rate 2
Load Retry Count 0
Load Cycle Count 62
ATA Error Count 0
SMART Information for Disk 6
Model: Hitachi HDS723020BLA642
Serial: MN1240F33MZ28D
Firmware: MN6OA800
SMART Attribute
Raw Read Error Rate 0
Throughput Performance 82
Spin Up Time 421
Start Stop Count 24
Seek Error Rate 0
Seek Time Performance 25
Power On Hours 21978
Spin Retry Count 0
Power Cycle Count 24
Power-Off Retract Count 28
Load Cycle Count 28
ATA Error Count 0
Disks
Passed diagnostics.
Memory
Passed diagnostics.
Network
Passed diagnostics.
Performance
* Jumbo frames are disabled on interface 1. If both your switch and clients support jumbo frames, you can enhance your write performance by enabling jumbo frames on this interface.
* Jumbo frames are disabled on interface 2. If both your switch and clients support jumbo frames, you can enhance your write performance by enabling jumbo frames on this interface.
Volume
Passed diagnostics.
Thoughts?
