cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
dsm1212
Nov 10, 2014Apprentice
Did you get a drive utility from samsung with the usb drive? I think there should have been one with it or you can download it from samsung.
FWIW Do you have your usb drives (and NAS) on a battery backup? The corrupt folder you had before looks like what you can get when you have a power outage. I'm sure there are other ways, but that is definitely one way to get there.
steve
steve
