cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
mdgm-ntgr
Apr 25, 2015NETGEAR Employee Retired
CPU is the main thing. Monitor the memory usage and if the swap isn't being used then a memory upgrade would likely only have marginal benefit.
You can use e.g. Plex to transcode 1080p MKVs.
