mharring54
Apr 20, 2017Aspirant
Netgear Genie update
I'm using Netgear Genie v. 2.4.10 and it keeps crashing. Trying to update but the update routine hangs on "Getting the description file..." Can't seem to find a download on the Netgear site. I use wi...
- Apr 20, 2017
Thanks. The wireshark is useful. Turns out it was my Amazon FireTV stick - problem solved. But the Netgear Genie is pretty neat for tracking network devices and referencing IP and MAC addresses. I'd like to update it and keep it from crashing everytime I open the network map.
Isn't there an easy update to download somewhere? The update from within my current version just hangs up.
mharring54
I'm trying to troubleshoot my LAN and WLAN and the Genie is the only software I'm aware of that I have to see all the devices with IP numbers, etc. The Network Map is what keeps crashing.
I seem to have some IP conflicts and trying to figure out what they are and why. I'm not sure if I have an intruder because there is one MAC address I don't recognize.
jak0lantash
Apr 20, 2017Mentor
This will help identify the manufacturer assigned to the OUI of the MAC address you see (though it's reasonnably easy to spoof a MAC address): https://www.wireshark.org/tools/oui-lookup.html
RAIDar will help check the IP addresses of your ReadyNASes: https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
