muzicman61
Dec 14, 2018Tutor
No Apps on RN104
I've searched and found a few solutions but none have worked. I came home from vacation and powered up my RN104 and could not get to the admin page or ssh into the device. I tried a OS reinstall an...
- Dec 15, 2018
Well after reviewing the logs and a little Google searching, I tried running a command via ssh. I ran apt-get update. Figured it couldn't hurt. It churned and churned for a while and then I rebooted the NAS. After that, I was able to install mysql, php and phpmyadmin. I also see a few featured apps showing up now but don't see anything under all apps. But I can always get apps from the apps.netgear.com site. So I guess I'm good. Still very strange. Thanks for your help pointing me to the logs.
Dec 14, 2018Guru - Experienced User
Have you confirmed that the NAS can reach the internet?
.freeapps doesn't hold the installed apps, it's where the NAS puts the available apps listings it gets from Netgear.
I've never seen an APPGENIE folder, so I don't understand that comment.
- muzicman61Dec 14, 2018Tutor
I was able to configure Dropbox on the NAS so I'm pretty confident it can access the internet. Is there a better way to confirm this?
The APPGENIE folder was just something i saw in a directory listing from another post where the user was having app issues.
- StephenBDec 14, 2018Guru - Experienced User
Since you have SSH, just ping somewhere on the internet from ssh. For instance, www.netgear.com
Pinging www.netgear.com from SSH was succesful.
