muzicman61
Dec 14, 2018Tutor
No Apps on RN104
I've searched and found a few solutions but none have worked. I came home from vacation and powered up my RN104 and could not get to the admin page or ssh into the device. I tried a OS reinstall an...
- Dec 15, 2018
Well after reviewing the logs and a little Google searching, I tried running a command via ssh. I ran apt-get update. Figured it couldn't hurt. It churned and churned for a while and then I rebooted the NAS. After that, I was able to install mysql, php and phpmyadmin. I also see a few featured apps showing up now but don't see anything under all apps. But I can always get apps from the apps.netgear.com site. So I guess I'm good. Still very strange. Thanks for your help pointing me to the logs.
muzicman61
Dec 14, 2018Tutor
I was able to configure Dropbox on the NAS so I'm pretty confident it can access the internet. Is there a better way to confirm this?
The APPGENIE folder was just something i saw in a directory listing from another post where the user was having app issues.
Dec 14, 2018Guru - Experienced User
Since you have SSH, just ping somewhere on the internet from ssh. For instance, www.netgear.com
- muzicman61Dec 14, 2018Tutor
Pinging www.netgear.com from SSH was succesful.
- StephenBDec 14, 2018Guru - Experienced User
Then the apps should be showing up in the available apps page :smileyfrustrated:
Maybe try again in a couple of hours, and see if it resolves?
You can download and install manually from apps.readynas.com
Well, it was factory reset yesterday afternoon and so far hasn't shown any apps. I downloaded mysql, php5 and phpmyadmin. When I upload any of the .deb files, I get an eror message that the application cannot be installed. :(
