muzicman61
Dec 14, 2018Tutor
No Apps on RN104
I've searched and found a few solutions but none have worked. I came home from vacation and powered up my RN104 and could not get to the admin page or ssh into the device. I tried a OS reinstall an...
- Dec 15, 2018
Well after reviewing the logs and a little Google searching, I tried running a command via ssh. I ran apt-get update. Figured it couldn't hurt. It churned and churned for a while and then I rebooted the NAS. After that, I was able to install mysql, php and phpmyadmin. I also see a few featured apps showing up now but don't see anything under all apps. But I can always get apps from the apps.netgear.com site. So I guess I'm good. Still very strange. Thanks for your help pointing me to the logs.
Dec 15, 2018Guru - Experienced User
Maybe try getting the mysql and php apps from rnxtras.com. There is a small cost, but you will get installation support from WhoCares_
muzicman61
Dec 15, 2018Tutor
