rmadrid20
Aug 27, 2015Tutor
Plex and my readynas 102 and access
I did install plex server in my ready nas but for some reason when I'm trying to access it from my nvidia shield TV tells my that I have to update the software and I have the latest software iny ready...
- Aug 27, 2015
Can this TV access other devices on your network or the internet?
Sounds like it could be a network connectivity issue.
Aug 27, 2015Guru - Experienced User
rmadrid20 wrote:
I did install plex server in my ready nas but for some reason when I'm trying to access it from my nvidia shield TV tells my that I have to update the software and I have the latest software iny ready nas, don't k know what to do next...
Probably it is telling you that you need to update the plex server app on the NAS. If you don't see an "update" button next to the plex icon (on the NAS admin web ui), you can download the current arm version from http://apps.readynas.com/pages/?page_id=9. Then you should see an update on the "available apps" page of the web UI (per the instructions on the above link).
Now my other question is this, yesterday my modem atoped working and for some odd reason I couldn't access my nas from my laptop, do I need internet to access my nas? I tough is a storage unit I can access thru my network without needing internet, maybe I'm doing something completely wrong here..
Thanks all for stopping by
You need to have a working local area network, but you do not need internet access. Did you try using the NAS IP address (https://nasip/admin, or \\nasip\share in windows explorer?). Note the direction of the slashes, that does matter.
rmadrid20
Aug 27, 2015Tutor
Ok so I came home, repair the internet and now "yes" i see the update plex app in the reay nas, im rigth now updating the app as I answer this post...................................................ok its updated now to the 0.9.12.8.1362-4601e39, and im going to my Nvidia Shield TV and try to conect to the server and tells me "NO SERVER FOUND SERVER VERSION 0.9.7.13 OR HIGHER REQUEIRED" as you see i hae a higher update, that is my issue
- mdgm-ntgrAug 27, 2015NETGEAR Employee Retired
Have you tried rebooting the NAS and your TV?
Do you have PlexPass?- rmadrid20Aug 27, 2015Tutor
let me try rebooting the nas and i dont have plex pass :(
I think there has recently been an update for Plex for SMART TVs. Have you checked for an update for Plex on your TV?
NOTHING after reboothing i get the same error :( frustrating
