SleepyZeebop
Aug 18, 2011Aspirant
Problem with redirect
Hi,
I have some problems with the redirect. According to the application the name and I get an Url to access the application. But when I try the link I only get to the www.readynas.com page instead.
The Diagnose went well with no errors.
Any ideas?
Best Regards
Daniel
Any ideas?
Best Regards
Daniel
- pstTutor+1 bump... http://photos.readynas.com/eighteengray gets redirected to www.readynas.com
Going directly to public-ip-address:8086 works just fine. - SleepyZeebopAspirantJust to add that my public address also works but the redirected one does not http://photos.readynas.com/keereweer
I'm behind a Airport Extreme so uPnp doen't work, so I configured it manually. Just the 8086 port.
Best Regards
Daniel - mlordAspirantI'm having the same issue. Did anyone have any success resolving this. I also cannot login using my public IP and 8086.
What format have you guys used to get in this way? ie: http://xx.xx.xx.xxx/8086 ??
Thanks for any help. - mlordAspirantNot sure what's up but this morning everything is working. :)
