jiska78
Aug 02, 2016Tutor
Problems installing Python
Something is very stuffed in my NAS. I'm trying to install Python and I'm getting all sorts of problems. I've been googling for days and tried a hundred different ideas but nothing seems to be wo...
- Aug 15, 2016
Actually as this is doing weird things using SSH i.e. installing the wrong Python package this definitely is something for the community not for a support case. As mentioned in https://community.netgear.com/t5/Current-NETGEAR-and-Partners/Problems-installing-Python-27233558/m-p/1127481 the problem has probably been resolved this time.
JennC
Aug 02, 2016NETGEAR Employee Retired
Hello jiska78,
What's the model and FW version of your NAS? Did you try installing through the admin page > Apps > Available apps if you have a ReadyNAS OS6?
- jiska78Aug 02, 2016Tutor
Hi Jen,
Thanks for your reply, but none of those things are really relevant. The problem exists at shell level and has nothing to do with the webservices gui that Netgear have installed on the box.
However, I have a ReadyNAS314, on firmware version 6.5.1 and yes I have tried installing via the GUI, which as far as I know simply executes the apt-get command on the backend, and it fails.
- JennCAug 03, 2016NETGEAR Employee Retired
Hello jiska78,
I see, then I think it is best if you contact support center about this.
I checked your profile and found that you are a PowerShift member, please contact support center to report this so it can be escalated to higher tier.
- jiska78Aug 03, 2016Tutor
Support won't be able to assist me - this is not a Netgear problem, it is a Linux one - that is why I'm posting in the community forums instead of lodging a support case???
- mdgm-ntgrAug 15, 2016NETGEAR Employee Retired
