jiska78
Aug 02, 2016Tutor
Problems installing Python
Something is very stuffed in my NAS. I'm trying to install Python and I'm getting all sorts of problems. I've been googling for days and tried a hundred different ideas but nothing seems to be wo...
- Aug 15, 2016
Actually as this is doing weird things using SSH i.e. installing the wrong Python package this definitely is something for the community not for a support case. As mentioned in https://community.netgear.com/t5/Current-NETGEAR-and-Partners/Problems-installing-Python-27233558/m-p/1127481 the problem has probably been resolved this time.
jiska78
Aug 02, 2016Tutor
Hi Jen,
Thanks for your reply, but none of those things are really relevant. The problem exists at shell level and has nothing to do with the webservices gui that Netgear have installed on the box.
However, I have a ReadyNAS314, on firmware version 6.5.1 and yes I have tried installing via the GUI, which as far as I know simply executes the apt-get command on the backend, and it fails.
mdgm-ntgr
Aug 15, 2016NETGEAR Employee Retired
