KennyRobb
May 27, 2020Aspirant
Problems with Backup to USB HDD
OK in order to hep fix another problem with my RN104 I am trying to backup everything to a USB external HD. RN104 Firmware 6.10.3 4x 2TB WD Red Drives (Raid 5) external HD WD My Passport (1TB) ...
May 27, 2020Guru - Experienced User
KennyRobb wrote:
3. Format Drive as EXT4 (saw recommendation somewhere else on forum)
A backup you can't access on another computer isn't worth very much.
EXT4 formatting is fine if you have other linux systems. But if you have don't, then NTFS is a better choice.
