KennyRobb
May 27, 2020Aspirant
Problems with Backup to USB HDD
OK in order to hep fix another problem with my RN104 I am trying to backup everything to a USB external HD. RN104 Firmware 6.10.3 4x 2TB WD Red Drives (Raid 5) external HD WD My Passport (1TB) ...
Marc_V
May 27, 2020NETGEAR Employee Retired
This usually happen when the drive was not properly unmounted or ejected.
You may want to check this link and perform the steps recommended and see if it will help.
https://kb.netgear.com/29402/ReadyNAS-OS-6-USB-drive-is-mounted-as-read-only
HTH
KennyRobb
I have followed the instruction in the post and still no luck.
1. Plug HD inot PC and reformat as NTFS
2. Made sure to eject drive
3. Put drive inot front port on RN104
4. Create new backup job pointiung backup at front USB port
5. Job Runs then Fails
Backup Job Name: job_001 Backup Job Type: Full Protocol: local Backup Source: [Documents]/ Backup Destination: [USB Front]/ Backup Start Time: Wed May 27 2020 10:16:16 AM Backup Finish Time: Wed May 27 2020 10:37:31 AM Backup Status: Fail: Destination is read-only or files/folders could not be created. Check if these files or folders meet the destination file system limitation. Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1709 - The Clans, Warriors of Kerensky.pdf' (error: Input/output error)! Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1710 - Twilight of the Clans.pdf' (error: Input/output error)! Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1711 - Field Manual, Warden Clans .pdf' (error: Input/output error)! Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1712 - Shattered Sphere.pdf' (error: Input/output error)! Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1713 - Operation Stiletto.pdf' (error: Input/output error)! Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1714 - Field Manual, Comstar.pdf' (error: Input/output error)! Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1715 - MechWarrior 3rd Edition - Character Sheet-DONE.pdf' (error: Input/output error)! Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1716 - MechWarrior Guide to Solaris VII.pdf' (error: Input/output error)! Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1717 - Capellan Confederation.pdf' (error: Input/output error)! Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1718 - Aerotech 2.pdf' (error: Input/output error)! Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1725 - Mechwarrior's Guide to the Clans.pdf' (error: Input/output error)! Cannot create file '/media/USB_HDD_4/Books/Battletech/Battlelist.txt' (error: Input/output error)! Cannot create file '/media/USB_HDD_4/Books/Battletech/Thumbs.db' (error: Input/output error)! Cannot create directory Books/Grey Hat Stuff! Cannot create directory Books/Star.Wars.Millennium.Falcon.Owner's.Manuel! Cannot create directory Clan Wolf Web Site! Cannot create directory Document Archive! Cannot create directory Documents Backup November 2018! Cannot create directory Documents backup March 2018! Cannot create directory Downloads! Cannot create directory Fonts! Cannot create directory Installables! Cannot create directory The Ancible Backup! Copy Folder .1567577503 Copy Folder .1567577503/._ngcloudignore_download Copy File .DS_Store Copy File ._.DS_Store Copy Folder Books Copy Folder Books/Battletech Copy File Books/Battletech/BattleTech - Aerotech 2 Fighter - Record Sheet - FASA.pdf Copy File Books/Battletech/BattleTech - Book of Mechs - RS.pdf Copy File Books/Battletech/BattleTech - Complete Classic Universe .pdf Copy File Books/Battletech/BattleTech - Deckplans - Dropship - Pioneer X.pdf Copy File Books/Battletech/BattleTech - Ground Vehicle & Vtol - Record Sheet - Level 3.pdf Copy File Books/Battletech/BattleTech - Ground Vehicle Record Sheet.pdf Copy File Books/Battletech/BattleTech - Infantry Record Sheet.pdf Copy File Books/Battletech/BattleTech - Inner Sphere Cicra 3040 .pdf Copy File Books/Battletech/BattleTech - Inner Sphere Map Jumpship Paths 3062.pdf Copy File Books/Battletech/BattleTech - Large Craft Record Sheet.pdf Copy File Books/Battletech/BattleTech - Magazine - BattleTechnology # 001.pdf Copy File Books/Battletech/BattleTech - Magazine - BattleTechnology # 002.pdf Copy File Books/Battletech/BattleTech - Magazine - BattleTechnology # 003.pdf Copy File Books/Battletech/BattleTech - Magazine - BattleTechnology # 004.pdf Copy File Books/Battletech/BattleTech - Magazine - BattleTechnology # 005.pdf Copy File Books/Battletech/BattleTech - Magazine - BattleTechnology # 007.pdf Copy File Books/Battletech/BattleTech - Magazine - BattleTechnology # 015.pdf Copy File Books/Battletech/BattleTech - Magazine - BattleTechnology # 021.pdf Copy File Books/Battletech/BattleTech - Magazine - Commander Quarterly, Issue 3067 - (WizKids Product).pdf Copy File Books/Battletech/BattleTech - Magazine - The Tech Factory 04.pdf Copy File Books/Battletech/BattleTech - Magazine - The Tech Factory 05.pdf Copy File Books/Battletech/BattleTech - Map IS Circa 2750.pdf Copy File Books/Battletech/BattleTech - Map IS and Clan Circa 3063.pdf Copy File Books/Battletech/BattleTech - Map Jumpship Paths 3025-DONE.pdf Copy File Books/Battletech/BattleTech - Mech Record Sheets - FASA 3025.pdf Copy File Books/Battletech/BattleTech - Mechwarrior 3rd - Occupational Fields List-DONE.pdf Copy File Books/Battletech/BattleTech - Mechwarrior 3rd Edition - Lifepaths - Master Document.pdf Copy File Books/Battletech/BattleTech - Mechwarrior III Battle Armor Design Rules.pdf Copy File Books/Battletech/BattleTech - Protomech - Record Sheet.pdf Copy File Books/Battletech/BattleTech - Quad Battlemech - Record Sheet - FASA.pdf Copy File Books/Battletech/BattleTech - Terrain Maps.pdf Copy File Books/Battletech/BattleTech 10970 - Technical Readout 3067.pdf Copy File Books/Battletech/BattleTech 10972 - Battletech Classic Map Set Compilation.pdf Copy File Books/Battletech/BattleTech 10974 - Fedcom Civil War.pdf Copy File Books/Battletech/BattleTech 10975 - Classic Battletech Companion.pdf Copy File Books/Battletech/BattleTech 10976 - Field Manual Update.pdf Copy File Books/Battletech/BattleTech 10977 Field Manual - Mercenaries (Rev).pdf Copy File Books/Battletech/BattleTech 10979 - Combat Operations.pdf Copy File Books/Battletech/BattleTech 10981 - Classic BattleTech Miniatures Rules.pdf Copy File Books/Battletech/BattleTech 10982 - Field Manual, Periphery.pdf Copy File Books/Battletech/BattleTech 10990 - Classic BattleTech Map Set Compilation 1.pdf Copy File Books/Battletech/BattleTech 10991 - Technical Readout, Project Phoenix.pdf Copy File Books/Battletech/BattleTech 10992 - Technical Readout 3026 (Revised).pdf Copy File Books/Battletech/BattleTech 11000 - Classic Universe.pdf Copy File Books/Battletech/BattleTech 1500 - Aerotech & Mechwarrior - Dropships & Jumpships.pdf Copy File Books/Battletech/BattleTech 1500 - Areotech & Mechwarrior - Dropships & Jumpships - Design Rules.pdf Copy File Books/Battletech/BattleTech 1604 - 4th Edition Boxed Set - Mech Sheets and Tables.pdf Copy File Books/Battletech/BattleTech 1604 - Battletech, 4th Edition Rulebook.pdf Copy File Books/Battletech/BattleTech 1605 - Tales of the Black Widow.pdf Copy File Books/Battletech/BattleTech 1606 - The Fox's Teeth.pdf Copy File Books/Battletech/BattleTech 1607 - Mechwarrior, 1st Edition Rulebook.pdf Copy File Books/Battletech/BattleTech 1608 - CityTech 2nd Edition.pdf Copy File Books/Battletech/BattleTech 1608 - Citytech (1st).pdf Copy File Books/Battletech/BattleTech 1609 - Aerotech.pdf Copy File Books/Battletech/BattleTech 1610 - Map Set #1.pdf Copy File Books/Battletech/BattleTech 1611 - BattleForce.pdf Copy File Books/Battletech/BattleTech 1612 - Succession Wars.pdf Copy File Books/Battletech/BattleTech 1612b - Succession Wars - Counter Sheet 1.pdf Copy File Books/Battletech/BattleTech 1612c - Succession Wars - Counter Sheet 2.pdf Copy File Books/Battletech/BattleTech 1612d - Succession Wars - Counter Set 3.pdf Copy File Books/Battletech/BattleTech 1613 - Galtor Campaign.pdf Copy File Books/Battletech/BattleTech 1614 - Cranston Snords Irregulars.pdf Copy File Books/Battletech/BattleTech 1615a Loki Technical Blueprint.jpg Copy File Books/Battletech/BattleTech 1615b MadCat Technical Blueprint.jpg Copy File Books/Battletech/BattleTech 1616 - The Mercenary's Handbook.pdf Copy File Books/Battletech/BattleTech 1617 - Gray Death Legion.pdf Copy File Books/Battletech/BattleTech 1619 - Dropships and Jumpships.pdf Copy File Books/Battletech/BattleTech 1620 - House Kurita, The Draconis Combine.pdf Copy File Books/Battletech/BattleTech 1621 - House Steiner, The Lyran Commonwealth.pdf Copy File Books/Battletech/BattleTech 1622 - House Marik, The Free Worlds League.pdf Copy File Books/Battletech/BattleTech 1623 - House Davion, The Federated Suns(auto full screens).pdf Copy File Books/Battletech/BattleTech 1624 - House Liao, The Capellan Confederation.pdf Copy File Books/Battletech/BattleTech 1625A - Battletech Reinforcements RS 3025.pdf Copy File Books/Battletech/BattleTech 1626 - The Rules of Warfare.pdf Copy File Books/Battletech/BattleTech 1627 - Sorensons Sabres.pdf Copy File Books/Battletech/BattleTech 1629 - The Periphery.pdf Copy File Books/Battletech/BattleTech 1630 - Star League.pdf Copy File Books/Battletech/BattleTech 1631 - Wolf's Dragoons.pdf Copy File Books/Battletech/BattleTech 1632 - Camo Specs.pdf Copy File Books/Battletech/BattleTech 1634 - NAIS 4th Succession War Military Atlas Vol 1.pdf Copy File Books/Battletech/BattleTech 1635 - NAIS 4th Succession War Military Atlas Vol 2.pdf Copy File Books/Battletech/BattleTech 1637 - Battletroops.pdf Copy File Books/Battletech/BattleTech 1638 - Map Set #3.pdf Copy File Books/Battletech/BattleTech 1639 - 20 Year Update.pdf Copy File Books/Battletech/BattleTech 1640 - The Battletech Compendium.pdf Copy File Books/Battletech/BattleTech 1642 - Wolf Clan.pdf Copy File Books/Battletech/BattleTech 1643 - Rhondas Irregulars.pdf Copy File Books/Battletech/BattleTech 1644 - Jade Falcon.pdf Copy File Books/Battletech/BattleTech 1645 - Invading Clans Sourcebook.pdf Copy File Books/Battletech/BattleTech 1646 - Living Legends, Star League.pdf Copy File Books/Battletech/BattleTech 1647 - Record Sheets Volume 1.pdf Copy File Books/Battletech/BattleTech 1648 - Medium Mechs Record Sheets 3025.pdf Copy File Books/Battletech/BattleTech 1649 - Heavy Mechs Record Sheets 3025.pdf Copy File Books/Battletech/BattleTech 1650 - Assault Mechs Record Sheets 3025.pdf Copy File Books/Battletech/BattleTech 1651 - Rolling Thunder.pdf Copy File Books/Battletech/BattleTech 1652 - Kell Hounds.pdf Copy File Books/Battletech/BattleTech 1653 - Battleforce, Battle Of Twycross.pdf Copy File Books/Battletech/BattleTech 1654 - Fourth Succession War Scenarios Vol 1.pdf Copy File Books/Battletech/BattleTech 1655 - Comstar (original).pdf Copy File Books/Battletech/BattleTech 1656 - Unbound.pdf Copy File Books/Battletech/BattleTech 1657 - More Tales of the Black Widow.pdf Copy File Books/Battletech/BattleTech 1659 - Solaris, The Reaches.pdf Copy File Books/Battletech/BattleTech 1660 - Gamemaster s Book.pdf Copy File Books/Battletech/BattleTech 1660 - Players Book.pdf Copy File Books/Battletech/BattleTech 1660 - Solaris VII Maps.pdf Copy File Books/Battletech/BattleTech 1663 - Map Set #4.pdf Copy File Books/Battletech/BattleTech 1664 - Clantroops.pdf Copy File Books/Battletech/BattleTech 1665 - Mechwarrior, Objective Raids.pdf Copy File Books/Battletech/BattleTech 1666 - Bloodright.pdf Copy File Books/Battletech/BattleTech 1667 - Record Sheets, Volume Five Vehicles.pdf Copy File Books/Battletech/BattleTech 1669 - Mccarrons Armored Cavalry.pdf Copy File Books/Battletech/BattleTech 1670 - Mercenary Handbook 3055.pdf Copy File Books/Battletech/BattleTech 1671 - MechWarrior Companion.pdf Copy File Books/Battletech/BattleTech 1672 - Null Set.pdf Copy File Books/Battletech/BattleTech 1673 - Intelligence Operations Handbook.pdf Copy File Books/Battletech/BattleTech 1676 - Royalty and Rogues.pdf Copy File Books/Battletech/BattleTech 1677 - Day of Heroes.pdf Copy File Books/Battletech/BattleTech 1678 - Luthien.pdf Copy File Books/Battletech/BattleTech 1679 Hot Spots, Contracts .pdf Copy File Books/Battletech/BattleTech 1679 - Hot Spots.pdf Copy File Books/Battletech/BattleTech 1680 - Battlespace.pdf.7j0j9lz.partial Copy File Books/Battletech/BattleTech 1681 - Explorer Corps.pdf Copy File Books/Battletech/BattleTech 1684 - The Fall Of Terra.pdf Copy File Books/Battletech/BattleTech 1685 - Tukayyid.pdf Copy File Books/Battletech/BattleTech 1686 - Black Thorns.pdf Copy File Books/Battletech/BattleTech 1687 - 1st Somerset Strikers.pdf Copy File Books/Battletech/BattleTech 1688 - Chaos March.pdf Copy File Books/Battletech/BattleTech 1689 - The Falcon and the Wolf.pdf Copy File Books/Battletech/BattleTech 1691 - BattleTech Compendium (Softcover) - RoW.pdf Copy File Books/Battletech/BattleTech 1692 - The Periphery.pdf Copy File Books/Battletech/BattleTech 1693 - Battle of Coventry.pdf Copy File Books/Battletech/BattleTech 1695 - Record Sheets 3025 & 3026.pdf Copy File Books/Battletech/BattleTech 1697 - First Strike.pdf Copy File Books/Battletech/BattleTech 1698 - Draconis Combine.pdf Copy File Books/Battletech/BattleTech 1699 - Free Worlds League.pdf Copy File Books/Battletech/BattleTech 1700 - Maximum Tech (Revised).pdf Copy File Books/Battletech/BattleTech 1701 - Field Manual, Mercenaries.pdf Copy File Books/Battletech/BattleTech 1702 - Northwind Highlanders.pdf Copy File Books/Battletech/BattleTech 1703 - Battleforce 2, Battletech Warfare on a Grand Scale.pdf Copy File Books/Battletech/BattleTech 1704 - The Dragon Roars.pdf Copy File Books/Battletech/BattleTech 1705 - Fourth Succession War.pdf Copy File Books/Battletech/BattleTech 1706 - Field Manual, Crusader Clans.pdf
when I look at the drive on my PC it needs a scan and a fix but there are some files that have been written as per the log.
Maybe its time to get a new NAS
Kenny
- StephenBMay 27, 2020Guru - Experienced User
Did you eject the drive before you removed it from the NAS? Windows and Mac PCs don't require that step any more, but the NAS does.
When the PC gives that prompt, then the NAS will mount the drive read-only. So run that scan.
I'm thinking it's more likely that you need a new USB hard drive.
You can test it with vendor tools in the PC (seatools for seagate or lifeguard for western digitial).
You can also try backing up the full share from the PC, using drag-and-drop, or possible a tool like teracopy or free file sync.
- KennyRobbMay 27, 2020Aspirant
Made sure that USB drive is/was ejected properly from each machine it was connected to.
The USB drive in question is about 4 weeks old, however to illiminate that I have opened a brand new 4TB external USB HD and am tying that right now.
Kenny
This is related to the other issue I have open at the moment about the performance of the NAS, it will take a long time to backup all the files doing it accross the NW.
Kenny
Update: I tried a backup of another part of the file system and it seemed to go without any errors.
Went back and looked at the error and it looks like it might be one of the files causing a problem.
Doing some final checks but it seem to be working now.
Thanks for all the help
Kenny
