Pete10p
May 22, 2021Aspirant
admin login keeps cycling every 2-3 seconds
I have just upgraded to 6.10.5 and now I can't get into the admin page. I can log in as usual but after 2-3 seconds I am asked to log in again. This keeps cycling. I have cleared the browser caches...
May 22, 2021Guru - Experienced User
Pete10p wrote:
but reinstalling the config is proving to be a problem with unknown server message popping up when trying to restore the file
Just downgrade to 6.10.4 first.
Unless you are confusing restoring the config with installing 6.10.4 firmware???
Pete10p
Reverting to 6.10.4 works fine and the systems works OK with login acting normally.
A seperate issue was that after I defaulted the OS and tried to reload my original config. When I did that that's when I got the server not recognised error message. I tried both over my lan and using a USB stick in the front usb port.
