Rockman
May 05, 2016Aspirant
Apps Will not Download/Install to RN104
When I try and install any of the many available apps listed, the Progress Bar says "Downloading" and shortly thereafter I get a box that says "Apps operation failed" and "Aplication xyz cannot be do...
- May 09, 2016
Well, I have no idea what I did right but things seems to be working. I reloaded the OS for the upteenth time, set the static IP address for my network and rebooted. Suddenly RC "sees" the machine and the app downloaded/installed. Beats the heck out of me.
Just sign me as "clueless"
May 07, 2016Guru - Experienced User
Is Outlook using an SMTP server?
Rockman
May 09, 2016Aspirant
Yes it is. I set the RN to the same settings.
Sidenote: As a test, I downloaded Photo-II using this browser from the webside and uploaded using the RN and it installed on the RN just fine. It's not the App I really wanted however but at least I know apps should install if I can download them. I have no idea about the email.
