Ringo155
May 18, 2016Aspirant
Firmware update (6.5) - Apps won't start, can't be installed oder deleted
Hi everbody, like most of you I updatet my Readynas 204 today. The update process itself went smoothly, but after the necesarry restart some problems arose. 1. I wanted to update Anit-Virus Plus, b...
- May 19, 2016
Edit: the fix in this post is no longer be needed.
Anyone else having this problem on an OS6 ARM system running 6.5.0 please download (EDIT LINK REMOVED)
If it self-extracts grab the zip file from the trash/recycle bin (if it is moved there). It is most important that you have the zip file that was downloaded.
Restore this zip file via System > Settings > Backup > RestoreYou will then be prompted to do a reboot.
About 4-5 minutes later the problem should then be fixed.
xander85
Jun 06, 2016Aspirant
Hi All, I was directed to this page from the CouchPotato Forums and I went to restore that config file. Now my NAS just has kfree+120 shown on the display. I am scared to touch it or reboot it. Is this normal? Will it just "fix itself"? Hopefully someone can assist. Thanks!
xander85
I had to hard reboot, it works okay now. But I am scared to touch this "fix" again. :(
Here is the original thread.
https://couchpota.to/forum/viewtopic.php?f=5&t=13033&p=39145#p39145
