Ringo155
May 18, 2016Aspirant
Firmware update (6.5) - Apps won't start, can't be installed oder deleted
Hi everbody, like most of you I updatet my Readynas 204 today. The update process itself went smoothly, but after the necesarry restart some problems arose. 1. I wanted to update Anit-Virus Plus, b...
- May 19, 2016
Edit: the fix in this post is no longer be needed.
Anyone else having this problem on an OS6 ARM system running 6.5.0 please download (EDIT LINK REMOVED)
If it self-extracts grab the zip file from the trash/recycle bin (if it is moved there). It is most important that you have the zip file that was downloaded.
Restore this zip file via System > Settings > Backup > RestoreYou will then be prompted to do a reboot.
About 4-5 minutes later the problem should then be fixed.
Mhynlo
Jun 06, 2016Luminary
xander85 Which CouchPotato App are you using?
There were some fixes to my CouchPotato app that is posted here:
xander85
Jun 06, 2016Aspirant
Mhynlo currently, nothing. Since the FW update of the RN104 I have not been able to get it running. It refused to launch and it would not uninstall. After some research, I was able to uninstall it. But now, nothing will reinstall. Perhaps I can manually install from that .deb from here?
https://github.com/Mhynlo/rn-couchpotato/releases/download/3.0.1-1/couchpotato_3.0.1-1_all.deb
ps. I was the one having issues with SickRage you assisted me with. It seems the FW update caused more problems than solutions. :(
