NT_2112
Dec 08, 2019Follower
Not able to install Portainer after upgrade to 6.10.2
Running 6.10.2 on a ReadyNas 424. After trying to install Portainer, the install fails and the ReadyNas admin login page appears. Portainer is not installed. I downloaded the logs via the web a...
givememynamebak
Apr 03, 2020Luminary
Mhynlo just created a release that seems to work for me: https://github.com/Mhynlo/readynas-portainer/releases/tag/1.16.4-ml1
yoban
Apr 12, 2020Apprentice
Hi there
Not wanting to hijack the thread as it is good to see Mhynlo create a fix, but was wondering how to update from version 1.16.4-ml0 which is runnign on OS6.9.5?
Will an update be available via "readynas app store"? Or could I load the latest DEB file from his gitub account and install, hoping it will not break any containers.
Thoughts or tips?
- givememynamebakApr 13, 2020Luminary
I doubt portainer would break any current containers as it's just a management tool. You could try to upgrade from new release (https://github.com/Mhynlo/readynas-portainer/releases/tag/1.16.4-ml1), and if that fails - just re-install the old one and you should be back to where you are now I would think. I'm not sure what versions the new one is compatible with but it might just work. If it were me, I'd always try the latest version before I try an older version.
- givememynamebakApr 22, 2020Luminary
For what it's worth: I installed the deb file and it worked fine. Not the one in the app store, and I have no idea if he's planning to update that.
