NT_2112
Dec 09, 2019Follower
Not able to install Portainer after upgrade to 6.10.2
 Running 6.10.2 on a ReadyNas 424.  After trying to install Portainer, the install fails and the ReadyNas admin login page appears.  Portainer is not installed.     I downloaded the logs via the web a...
givememynamebak
Apr 14, 2020Luminary
I doubt portainer would break any current containers as it's just a management tool. You could try to upgrade from new release (https://github.com/Mhynlo/readynas-portainer/releases/tag/1.16.4-ml1), and if that fails - just re-install the old one and you should be back to where you are now I would think. I'm not sure what versions the new one is compatible with but it might just work. If it were me, I'd always try the latest version before I try an older version.
givememynamebak
Apr 22, 2020Luminary
For what it's worth: I installed the deb file and it worked fine. Not the one in the app store, and I have no idea if he's planning to update that.
