JFRedwards
May 10, 2020Aspirant
RN10400 NAS won't boot HELP
I have a office Ready NAS that won't boot or show a managment menu. Files are not accessable, data recovery is imporant. Front panel says booting then goes black and no data when I touch the power b...
May 13, 2020Guru - Experienced User
Also, what apps do you have installed? There are some that fill up the OS partition (loganalyzer being one).
The Readynas application does rotate the logs. My RN526x has been running since late 2016, and the root partition usage is quite steady at about 27% full.
JFRedwards
May 13, 2020Aspirant
Here is what the device says it has installed,
iRedmail and readynas surveillance (picture attached), would iredmail have been installed for system error messages?
No plex was ever installed from what I can tell, the USB drive issue is more likely and also an update that went sideways.
How and where would I look for these?
- SandsharkMay 13, 2020Sensei
With no USB drive connected, look in /media. It should be empty.
- StephenBMay 13, 2020Guru - Experienced User
No, but if it's not something you use then you should uninstall it.
