Suncoaster
Aug 26, 2015Aspirant
Stuck in Setup Wizard
This is the error I get when I attempt to finish the setup of this application. What do I need to do to fix this problem.
mdgm-ntgr
Aug 28, 2015NETGEAR Employee Retired
Please send in your logs (see the Sending Logs link in my sig).
Suncoaster
Aug 28, 2015Aspirant
Log files sent as requested.
Regards
- mdgm-ntgrAug 28, 2015NETGEAR Employee Retired
Can you verify if UPNP is enabled and working properly?
Could you also test as an alternative port forwarding the port for Photos II? - SuncoasterAug 29, 2015Aspirant
I can confirm that UPNP is enabled but how can I test if it working? Also how can I change the port used in the app. By default the app chose 8086 as the port and I cannot change it. Are there any installation instructions available for this app that may help me out.
Regards
- Retired_MemberSep 04, 2015
Hello,
I have the exact same problem than Suncoster, same error message during the Setup Wizard.
I on a RN516, firmware 6.2.4 and version 2.0.5 of ReadyNAS Photos 2.
I tried from Chrome and Firefox on Mac it didn't work.
Thank you in advance for the help.
Best!
- matmarSep 18, 2015Guide
Me too RNNAS516 6.4 Beta 5
exact same issue.
I also have a RNDU4000 with which no issue on the same network.
Thanks in advance
