Lionelv00's avatar
Lionelv00
Subversion addon - connection refused
Hi all,   readynas ultra 2   I've installed the subversion addon from rnxtras. Now when I try to checkout I get connection refused. Here are the steps I followed:   On the readnas: NetgearNAS:...
  • WhoCares_'s avatar
    WhoCares_
    Aug 16, 2015
    Sorry for the late reply, still trying to get used to the new "forums".
    Actually, you were already close. You created the SVN repo correctly but the correct command to checkout a repo from the ReadyNAS would be
    svn checkout https://192.168.1.100/svn/SVNTest
    Two things to note here: For accessing the Repo you have to either use the HTTP or the HTTPS protocol, not SVN. And for the path to the repo you habe to prefix the repo's name with "/svn/".
    When pushing changes to the ReadyNAS you'll have to authenticate using a valid username/password combination as defined on the ReadyNAS.
    -Stefan
ProSupport for Business
