Peter0284
Jun 27, 2017Aspirant
Unable to install Plex on my RN102
Good afternoon can anyone help please. I have a ReadyNas RN102 running Plex to view videos on Fire TV, it has been running with no problems for over 12months, last weekend the Fire TV came up wit...
- Jul 01, 2017
Stephen, Jenn,
I've solved it and managed to upload PLEX, I had installed Nero home media and as a test so I removed it and as soon as it was un-installed PLEX loaded and its now working fine.
Thank you for taking the time to help.
Regards Pete
JennC
Jun 28, 2017NETGEAR Employee Retired
Hello Peter0284,
To download the logs:
- Open the web interface*.
- Go to System > Logs.
- Click the Download Logs button.
Then upload to www.wikisend.com and then PM me the download link.
Peter0284
Jun 28, 2017Aspirant
Jennc I hope this is what you need.
http://wikisend.com/download/117550/System_log-RN102-20170628-230522.zip
Regards Pete
- JennCJun 28, 2017NETGEAR Employee Retired
Hello Peter0284,
Which Plex version did you install? Have you tried plexmediaserver-ros6-binaries_1.7.5.4035-313f93718_armel from the https://www.plex.tv/downloads/ link?
If you have other apps running, maybe try disabling them for the meantime and install the app.
- Peter0284Jul 01, 2017Aspirant
Good morning Jenn
sorry for the delay replying, I have downloaded that link and tried to load the version you recommend without success, I only have one other app installed which i switched off.
Do you have any other recommendation's ? I only bought the Nas to run PLEX so really frustrating if i cant be he app back on the system.
Thank you in advance.
Pete
