Peter0284
Jun 27, 2017Aspirant
Unable to install Plex on my RN102
Good afternoon can anyone help please. I have a ReadyNas RN102 running Plex to view videos on Fire TV, it has been running with no problems for over 12months, last weekend the Fire TV came up wit...
- Jul 01, 2017
Stephen, Jenn,
I've solved it and managed to upload PLEX, I had installed Nero home media and as a test so I removed it and as soon as it was un-installed PLEX loaded and its now working fine.
Thank you for taking the time to help.
Regards Pete
JennC
Jun 28, 2017NETGEAR Employee Retired
Hello Peter0284,
Which Plex version did you install? Have you tried plexmediaserver-ros6-binaries_1.7.5.4035-313f93718_armel from the https://www.plex.tv/downloads/ link?
If you have other apps running, maybe try disabling them for the meantime and install the app.
Peter0284
Jul 01, 2017Aspirant
Good morning Jenn
sorry for the delay replying, I have downloaded that link and tried to load the version you recommend without success, I only have one other app installed which i switched off.
Do you have any other recommendation's ? I only bought the Nas to run PLEX so really frustrating if i cant be he app back on the system.
Thank you in advance.
Pete
