xander85
Nov 10, 2015Aspirant
Uninstall SickBeard
Hi All, I am a new user to the ReadyNAS family. Recently it was suggested to me by a stanger at PAXaus to try sickbeard. So I attempted to install, seemed okay. But it refused to "switch on". Now...
JennC
Nov 12, 2015NETGEAR Employee Retired
Hello xander85,
Please see this article and observe if you get the same problem.
If same problem, you may try ReadyNASOS 6.4.1-T29 (Beta 2).
xander85
Nov 12, 2015Aspirant
In my very first post, I stated that I was already running 6.4.0
ReadyNAS FW version is 6.4.0
Is there a way I can SSH into it and forcibly remove it? I would like to avoid Beta Firmware if I can.
