flombs75
Mar 31, 2020Aspirant
ready nas rnd-2d not working, need to access files on discs
Hi, Our ReadyNAS RN10200 rnd-2d has stopped working and I need to access the files on the discs that were inside the NAS. I know it is an old product, would there be a newer product available that ...
- Mar 31, 2020
Any current ReadyNAS should be able to access your volume, assuming that the volume isn't the problem you have now. So it is a good idea to do some troubleshooting, even if you decide it's time to upgrade the NAS, before you declare it's the hardware that's the problem..
If you move the drives from the old to the new, with power off, and then power on, it should mount your old data volume and all will be well. It is best that the new NAS is on the same OS version as the old, though it really shouldn't cause any serious problems unless your old NAS firmware was way out of date. If you have apps installed and you move to an Intel based NAS, they will not longer function. We normally recommend you remove them on the old NAS before the migration, but that's not possible if the old NAS is broken. So, you'll have to try to remove them once the volume is in the new NAS and then replace them with an x86 version if you still need them.
Marc_V
Mar 31, 2020NETGEAR Employee Retired
Welcome to the Community!
What is the current status of the NAS? Is it not powering on? If it is turning on, you may want to check the status of the NAS using RAIDar utility so if there's a chance to bring it back working then we may be able to help.
If it is already dead and it is under 3 years then you may want to contact Support so they can have it replaced. If you are planning on purchasing a new model you can directly migrate your disks to it as long as it is a ReadyNAS OS 6 firmware. You will be able to access your files after booting it normally.
HTH
Regards
flombs75
Apr 01, 2020Aspirant
Hi Marc,
We recently moved and I plugged in the wrong power plug in and it blew the motor. There was a flash and smoke.
Thankfully I removed the discs inside before this happened.
The ReadyNAS 212 - 2 Bay Diskless could be considered a straight swap?
Thanks in advance.
