bluearchitect
Jul 15, 2023Aspirant
ReadyCloud Sign in error on RN10200
Desktop Client login shows error message. I've followed instructions as per https://kb.netgear.com/29379/ReadyCLOUD-Client-Sign-In-Error but still cannot gain access. When looking at settings the sof...
- Jul 15, 2023
bluearchitect wrote:
am I better deleting the ReadyCloud software first and then loading FreeFileSync. I don't want to lose access or any files which are on the backup (not all are to be sync'd)
You can install FreeFileSync first, and set it up to sync to the same folder that the ReadyCloud backup is using. Or if you prefer, you can set up a new share for FreeFileSync, and then delete the ReadyCloud target folder after FreeFileSync has finished syncing.
Jul 15, 2023Guru - Experienced User
Note the banner at the top of the forum page. ReadyCloud has been shut down.
If you are just using the backup feature of the client, you can use FreeFileSync as an alternative.
- bluearchitectJul 15, 2023Aspirant
Thanks StephenB
I am only using it as a backup and probably have only remoted in twice in four years, so losing that option is no biggy.
It may be outside of your knowledge but am I better deleting the ReadyCloud software first and then loading FreeFileSync. I don't want to lose access or any files which are on the backup (not all are to be sync'd)
Apologies I am not technically minded (and also miss banner notifications too :-))
- StephenBJul 15, 2023Guru - Experienced User
