Nienkerk
Jan 04, 2019Aspirant
ReadyNAS 104 admin page login fail
I've got this problem where I can access the NAS from explorer on my PC and I've shared lots of media to my mediaserver and that works great but i cant login to the admin page on the NAS. So basi...
- Jan 04, 2019
The username is admin
If you can't recall the password, you will need to do an OS reinstall from the boot menu. That will
- reset the admin password to password.
- reset the network configuration to the default DHCP
- turn off volume quota (on the volume settings wheel)
Data and other settings shouldn't be affected.
Instructions for doing the OS reinstall is on pages 28-29 of the hardware manual here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
Jan 04, 2019Guru - Experienced User
Nienkerk
Thanks! Ill read up a bit and maybe try it later tonight.
