CrazyCraig
Jul 28, 2022Aspirant
readyNas 214 no longer showing shares
Hello, I am experiencing an issue where the shares I have created on my readynas have disappeared in the web admin page. The shares page shows empty, but the usage shows there is about 11tb of my 27...
- Jul 28, 2022
Good thing you have replaced the drives getting high errors. OS volume is fine as well as data. The resync might have cause something. Will you be able to set the NAS on SDM? We may have to take a look.
Also, if you can access your data, it would be best to have a backup of it.
HTH
Jul 28, 2022Guru - Experienced User
CrazyCraig wrote:
Hello, I am experiencing an issue where the shares I have created on my readynas have disappeared in the web admin page. The shares page shows empty, but the usage shows there is about 11tb of my 27tb system free. I am able to browse some of the shares from some of the computers on my network, but some of the shares show they are empty. I am not sure what to do or where to turn to. I don't see anything out of the ordinary in the logs available in the web page. I have downloaded the complete log bundle but I don't know what to look for. If anyone has any hints or idea of what to look for I would appreciate it.
Are you seeing a full root message anywhere?
You can try sending a private message (PM) to the mods ( Marc_V and/or JeraldM ) and ask them to review the log zip for you. You send a PM using the envelope icon in the upper right of the forum page. Put the zip in cloud storage (google drive, icloud, dropbox, etc), and put a download link in the PM.
BTW, don't post a link to the log zip publicly, there is some information leakage if you do that.
