CrazyCraig
Jul 28, 2022Aspirant
readyNas 214 no longer showing shares
Hello, I am experiencing an issue where the shares I have created on my readynas have disappeared in the web admin page. The shares page shows empty, but the usage shows there is about 11tb of my 27...
- Jul 28, 2022
Good thing you have replaced the drives getting high errors. OS volume is fine as well as data. The resync might have cause something. Will you be able to set the NAS on SDM? We may have to take a look.
Also, if you can access your data, it would be best to have a backup of it.
HTH
Marc_V
Jul 28, 2022NETGEAR Employee Retired
Welcome to the Community!
What was the last activity you have done before this happened? Did you perform an upgrade? If you can upload your full logs to a share service and provide me the link to download it via PM I can take a look.
HTH
CrazyCraig
Marc_V I have sent you a PM with the requested information. I have done nothing prior to this issue. I don't even know when it happened as I was able to browse the shares prior to this morning on my PC on the same network.
- Marc_VJul 28, 2022NETGEAR Employee Retired
HTH
- CrazyCraigJul 28, 2022Aspirant
I did replace that last failed drive back in March I believe. I would have to purchase an additional drive to try to copy/backup about 6tb of data. I guess it would be best to try to save that data while I still have access to it before enabling SDM.
- CrazyCraigAug 03, 2022Aspirant
Mark_V thank you again for your help in this matter. I was able to restore the shares using the instructions you provided.
