adomenicus
Sep 29, 2023Aspirant
ReadyNAS 516 cannot mount RAID volume
Good afternoon! I am trying to access data on my ReadyNAS 516, using firmware 6.10.8. It has 6 drives of 4TB each, running in a RAID 5 configuration. After a batch of storm-caused power interruptions...
- Oct 02, 2023
Thanks to StephenB I was able to mount the volume using
mdadm --assemble --really-force /dev/md127 /dev/sd[abcdef]3and then painfully copy all folders and files onto spare external drives. I say painfully because the NAS was trying to rebuild the RAID drive while doing so, and performance was a dismay. While I am sure there is a way to safely prevent that, I did not try as data recovery was priority #1.
So now I can say that all data has been recovered, and I have ordered the disks to start brand new and build a new RAID drive to dump the restored data into. I have also ordered a large drive to make a regular backup ... just in case.
Thanks to StephenB and the community. You rock!!
Sep 29, 2023Guru - Experienced User
adomenicus wrote:
when I SSH using the admin account and password, ...
the connection is closed.
You need to log in as root using the NAS admin password.
adomenicus wrote:
Looking at the logs it seems that volume 1 was resynced, but then there was a fault in disk 6 and as a consequence the RAID volume could not be assembled.
I am thinking that the resync might not have been fully completed (perhaps the volume was vertically expanded in the past?). Download the full log zip file, and take a look there.
If you like, I could take a look. If you are interested, put the zip into cloud storage and PM me a download link (using the envelope icon in the upper right of the forum page). Make sure the permissions are set so anyone with the link can download.
adomenicus
Oct 02, 2023Aspirant
