Bill_NYC_229
Nov 24, 2018Aspirant
ReadyNAS Duo can't figure out how to install add-ons
I would like to install Minimserver on my ReadyNAS Duo, but I don't see how to install add-ons. Can anyone help me? Photo of my Raidar Home page attached.
If you are getting the binary from https://minimserver.com/install-readynas.html, then it isn't compatible with your duo v1. There are packages for OS 4.2, OS 5, and OS 6, but not for OS 4.1 (sparc-based) ReadyNAS - which is what you have.
- Bill_NYC_229Aspirant
Thanks for the heads up. I’m guessing then that minimserver cannot be installed on my NAS(?).
It's not a package I've used, but I believe it cannot be installed on your NAS.
- JohnCM_SNETGEAR Employee Retired
Hi Bill_NYC_229,
Welcome to the Community!
If you are trying to install the add-on manually, you should be able to do it by going to System > Update then go to the Local tab. You may check page 99-100 of the software manual for the steps as well.
