Superdan186
Mar 25, 2016Tutor
ReadyNAS Photos II How it work?
Hi, My Readynas RN104 firmware 6.5.0 T322. I have question to ReadyNas Photos II app. I launch app Photos II Login then I add photos which all my photos are in the nas picture folder, After adding ph...
- Mar 28, 2016
Well firstly if the photos are important then you should have a backup of them e.g. to a USB disk, another NAS, the cloud or some place else.
Secondly, when you delete photos from Photos II they are deleted from your Photos II library not from where you originally uploaded them from.
JennC
Mar 26, 2016NETGEAR Employee Retired
Hi Superdan186,
The Photos are saved to a hidden folder in the NAS that is accessible via ReadyNAS Photos app. I believe you have an option to download the photos using the app.
