ndpm
Feb 02, 2017Aspirant
readynas replicate question
Hi Guys, I have few ReadyNas 314 and I was planning on using the replicate fuction. WHat is saw is that everyday the replicate create a new folder and download all the files again, that not goo...
Feb 03, 2017Guru - Experienced User
ReadyDR might work better for you, though that depends on how the server images are updated on the primary NAS.
If the images are updated so only changed blocks are rewritten, then ReadyDR will track the changes. But if the entire image is rewritten the NAS has no way to identify the changes.
I believe ReadyDR would require a VPN connection between the sites (I don't believe it works over the internet yet).
