redstamp
Oct 03, 2016Apprentice
Resilio (formerly BTSync)
Saw an announcement from ghacks.net ref Resilio 2.4 (formerly BTSync 2.3) and their final extraction from BitTorrent: http://www.ghacks.net/2016/09/23/resilio-sync-2-4-released-former-bittorrent-syn...
JennC
Oct 04, 2016NETGEAR Employee Retired
Hello redstamp,
Are you trying to get Resilio app for ReadyNAS? I do not see this in the current available apps for ReadyNAS.
I suggest you post this at the Idea Exchange board. Adding kudos to the ideas will help as development team will be reviewing the post that has the most kudos for considering it to add to the product's future functionality.
We appreciate your contribution to the community!
- redstampOct 04, 2016Apprentice
Hi JennC,
I was assuming that the download provided for Resilio 2.4 on the getsync.com site under "Netgear NAS" would be suitable for the ReadyNAS:
https://help.getsync.com/hc/en-us/articles/206179364-Netgear
Are you saying I need to wait for Netgear to list it on the ReadyNAS apps page to be assured its compatible? Or do you think this version is for another type of Netgear NAS?
Will certainly post on the Ideas Exchange if you think this version cannot be installed on the ReadyNAS.
Jon
- mdgm-ntgrOct 04, 2016NETGEAR Employee Retired
Which model do you have and which firmware are you running?
If you are running OS6 then that app should work, but we either haven't tested it or it hasn't yet passed our basic testing of app compatibility.
Also note we have just released ReadyNAS OS 6.6.0. This includes a major update to the core OS and some apps will require updates to be compatible.- redstampOct 04, 2016Apprentice
Thanks JennC,
Didint realise new FW was available - I am on 6.5.2 on both my RN104's - and both are saying they are uptodate. Presume this is coming soon.
I had noticed that quite a few apps aren't in the Netgear Apps list though, as BT Sync isn't there, Plex isn't there and both used to be - so I cant work out the logic of what apps are listed...
Thanks,
Jon
