cchoate
Mar 21, 2017Aspirant
Resilio Sync resets after reboot
I have Resilio 2.4.4 installed on my Readynas 314 with firmware 6.6.1. I install the app, do the first time set up then add folders to start syncing. If I reboot my Readynas 314 Resilio sync looses a...
- Mar 24, 2017
JennC
Mar 23, 2017NETGEAR Employee Retired
Hello cchoate,
Did you get the app from apps download site or from the admin page's available apps?
Welcome to the community!
- cchoateMar 23, 2017Aspirant
Yes, I did download from the app download site on the Netgear web page. This issue seems to have started when I updated the firmware to 6.6.1 on my Readynas 314. Not sure if this is a bug on the Netgear firmware or the Resilio app.
- JennCMar 24, 2017NETGEAR Employee Retired
- JennCMar 27, 2017NETGEAR Employee Retired
Hello cchoate,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
