cchoate
Mar 21, 2017Aspirant
Resilio Sync resets after reboot
I have Resilio 2.4.4 installed on my Readynas 314 with firmware 6.6.1. I install the app, do the first time set up then add folders to start syncing. If I reboot my Readynas 314 Resilio sync looses a...
- Mar 24, 2017
JennC
Mar 24, 2017NETGEAR Employee Retired
JennC
Mar 27, 2017NETGEAR Employee Retired
Hello cchoate,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
