neo3010
Jul 17, 2014Aspirant
RN102 + Surveillance #23535821
I installed the add-on from the add-on page, however, when I go to logon using the default credentials of admin/netgear1 it doesnt work (states its invalid). Netgear online support has been less than helpful, anyone have any idea?
- lebouralAspirantI have a readynas 102 with 6.1.8 firmware.
The only other apps i have installed are ajaxplorer, barracuda drive, and Gateone
I ve tried login admin and ADMIN, password netgear1 and NETGEAR1 - lebouralAspirantwhere is stored the default password ? Can i verify the value ? (md5 or clear password)
- lebouralAspirantProblem resolved with admin/password as login/password
- Marto731AspirantHello,
To inform users, that the Surveillance manual has been updated, explaining this change.
http://support.netgear.com/product/RNNVR01L-1000S
Current password is " password ".
Previous versions of ReadyNAS Surveillance used the default password " netgear1 ".
If you upgrade to the latest version, and have never changed the default password, the password is changed to " password ".
