redcons's avatar
redcons
RN102 dropbox sync issue
Hi
I am wondering if someone can help with an issue I have with dropbox sync, I have a RN10200 with 2 X 1TB WD drives I have updated the firmware on the NAS to 6.4.2 and now dropbox is not synchronizing I have selected the folder and when I recreate a folder to sync and test to dropbox I get a flash pop up for a second and then nothing when I enter my credentials and press test all seems ok it goes and logs into my dropbox account but after that nothing the sync was working prior to the FW upgrade.
Can anyone offer advice please.
Cheers
Wayne
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi redcons,
    Welcome to the community! :)
    Have you tried to turn off then turn on Dropbox on the web-GUI of your RN102?
    DaneA
    NETGEAR Community Team
    • redcons's avatar
      redcons
      Hi Thanks for the reply yes it has been turned off and back on but issue is still present all dropbox files I am having to do manually.
      thanks
      Wayne
      • JennC's avatar
        JennC
        Hello redcons,
        Try resetting permission of the share and test again.
  • kohdee's avatar
    kohdee
    NETGEAR Expert
    Please check your network adapter DNS and Gateway and ensure they have proper values. DHCP should come automatically from your DHCP server (router, generally)... but if you set static, you may need to reconfigure the DNS.
  • Hi thanks for the response
     I have reset the permissions all networking is working fine this issue occured when I upgraded to the latest firmware dropbox just stopped working
    when I click synch in the backup a little circle appears for 2 seconds then disapears no errors no warnings, but nothing is being backed up the credentials I use are OK.
    Any hep is much appreciated
ProSupport for Business
