fencer019
Dec 14, 2021Aspirant
RN104 Wrong total disk Size
I have a RN104 with 2 drives, 1x4TB and 1x2TB configured as JBOD. I pulled out the 2TB and cloned the disk to a new 6TB and resized the partition to take the full size of the disk. When the 6TB was ...
Dec 14, 2021Guru - Experienced User
When the 6TB was plugged into the device, ReadyNAS correctly identified the disk as a 6TB but the total space available remained the same.
Is there a way to fix this?
I think all you need to do is manually expand the btrfs file system via ssh.
Since the volume is named data, the command would be btrfs filesystem resize max /data
If you haven't used ssh before:
- first enable it in system->settings->services
- then log in as root (for instance, enter ssh root@NAS-IP-ADDRESS from the windows search bar (using the real NAS IP address of course). The password is the same as your NAS admin password.
This is definitely done at your own risk.
Sandshark
Dec 14, 2021Sensei
How did you re-size the partition? The ReadyNAS JBOD still uses MDADM RAID, it just creates RAIDs without redundancy. If you didn't also expand the RAID, the file system won't expand because it's mounted on the RAID, not directly on the partition. What does cat /proc/mdstat return from ssh? Or alternately, what's the content of mdstat.log from the downloaded logs?
- fencer019Dec 15, 2021Aspirant
This is the output from cat /proc/mdstat
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md124 : active raid1 sdd3[0] 3902166784 blocks super 1.2 [1/1] [U] bitmap: 3/30 pages [12KB], 65536KB chunk md125 : active raid1 sda3[0] 971911808 blocks super 1.2 [1/1] [U] md126 : active raid1 sdc3[0] 3902167808 blocks super 1.2 [1/1] [U] md127 : active raid1 sdb3[0] 5855670784 blocks super 1.2 [1/1] [U] md1 : active raid10 sda2[0] sdd2[3] sdc2[2] sdb2[1] 1044480 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU] md0 : active raid1 sdd1[0] sda1[5](S) sdc1[4] sdb1[3] 4190208 blocks super 1.2 [3/3] [UUU] - fencer019Dec 15, 2021Aspirant
btrfs device usage /data
/dev/md124, ID: 1 Device size: 3.63TiB Device slack: 0.00B Data,single: 3.49TiB Metadata,single: 8.00MiB Metadata,RAID1: 3.00GiB Metadata,DUP: 16.00GiB System,single: 4.00MiB System,RAID1: 32.00MiB System,DUP: 16.00MiB Unallocated: 133.33GiB /dev/md127, ID: 2 Device size: 5.45TiB Device slack: 3.64TiB Data,single: 1.66TiB Metadata,RAID1: 3.00GiB Metadata,DUP: 20.00GiB System,RAID1: 32.00MiB Unallocated: 134.36GiB
- SandsharkDec 16, 2021Sensei
Since you didn't give details on all your drives, I'm guessing a bit, but md127 does appear to be 6TB. So expanding the BTRFS file system as StephenB suggested should be all that's necessary. But I think he got the command backwards btrfs filesystem resize /data max (assuming the volume name is data), though maybe it doesn't matter.
- StephenBDec 17, 2021Guru - Experienced User
The man page says btrfs filesystem resize max <path>. https://btrfs.wiki.kernel.org/index.php/Manpage/btrfs-filesystem So /data should be last.
