JFRedwards's avatar
JFRedwards
RN10400 NAS won't boot HELP
I have a office Ready NAS that won't boot or show a managment menu. Files are not accessable, data recovery is imporant.  Front panel says booting then goes black and no data when I touch the power button.
I have run dagnostics using raidar from NETGEAR. All drives show up with green checks, Firmware is 6.9.4.   I can not SSH in to device as I don't think that was ever enabled. Users say drives where not out of space but I don't know what to base that one on.
It seems to me that part of the volume is full as error logs are full of failed to create.  I was unable to download logs just what shows up in the dag window.  Is there an easy fix or is the best method for data recovery and replace the unit I guess?
HELP!
Dagnostics output
Volume root is 100.00% full
2019-10-20 06:02:12: ufsd: "mount" (sdd2): is mounted as NTFS at 2019-10-20 13:02:12
2019-10-13 06:02:10: ufsd: "mount" (sdd2): is mounted as NTFS at 2019-10-13 13:02:10
2019-10-10 06:02:01: ufsd: "mount" (sdd2): is mounted as NTFS at 2019-10-10 13:02:01
2019-10-06 06:02:11: ufsd: "mount" (sdd2): is mounted as NTFS at 2019-10-06 13:02:11
2019-10-04 06:02:13: ufsd: "mount" (sdd2): is mounted as NTFS at 2019-10-04 13:02:13
2019-09-30 06:02:11: ufsd: "mount" (sdd2): is mounted as NTFS at 2019-09-30 13:02:11
09 22:04:35: DB (main) schema version: 24 ==> 24
2020-05-09 22:04:35: rndb_create() ==> 3 (448ms)
2020-05-09 22:04:35: Error create table (db)
2020-05-09 22:04:35: dba create failed
2020-05-09 22:04:33: Failed to start ReadyNAS System Daemon.
2020-05-09 21:54:49: dba create failed
2020-05-09 21:54:48: Error create table (db)
2020-05-09 21:54:44: rndb_create() ==> 3 (1526ms)
2020-05-09 21:54:43: DB (main) schema version: 24 ==> 24
2020-05-09 21:54:33: Failed to start ReadyNAS System Daemon.
2020-05-09 21:44:33: DB (main) schema version: 24 ==> 24
2020-05-09 21:44:33: rndb_create() ==> 3 (480ms)
2020-05-09 21:44:33: Error create table (db)
Thanks in advance
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    JFRedwards
    Welcome to the Community!
    The Volume root is full as per the logs, the OS Volume and/or Data volume got full and that is one reason why your NAS is not booting up properly. Have you tried booting the NAS on Read only?
    if you are comfortable using SSH, you can boot the NAS on Tech Support mode and follow good instructions from posts answered by StephenB and others. Otherwise, another option would be to contact Support.
    HTH
    Regards
    • StephenB's avatar
      JFRedwards:
      ReadyNAS systems put a small OS partition on the disks (4 GB).  The system boots from the partition, and that is where linux and the ReadyNAS application are installed.  That partition is what we mean by "volume root".  It's not at all the same as the data volume.
      As Marc_V suggests, you can contact Netgear paid support (via my.netgear.com ) and have them fix this.  You could also look yourself, but there may be damage to the NAS configuration files which would be hard to troubleshoot - Netgear can repair those.  If you want to use paid support, it is best not to attempt repairs yourself.
      Either way, you would need to be in the office to boot up the NAS in tech support mode.  Netgear can then access the NAS remotely (using a code that is displayed on the LCD).  You could alternatively access the linux CLI using telnet.  We can give you some guidance on how to do that if you like.
      Instructions for booting into tech support mode are on pages 28-29 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
      • JFRedwards's avatar
        JFRedwards
        Thanks for everyones help,
        At this point I think using paid support is best, Hopefully there is a decent way to get it booted and working. If it was my device I would just do it myself, but with my guess being other configuration issues to arise I am sure it will be a pain.
        I need to backup the data right away after getting it working.
ProSupport for Business
