enxer's avatar
enxer
RN31200 - Installing virtualbox on ReadyNas 6.5.0
I just recently purchased a 312 and I've been following JMehring's post: https://community.netgear.com/t5/Community-Add-ons/Virtualbox-on-OS6-NAS/td-p/902756 and I get stuck on installing virtualbox (I am using the newest from virtualbox.org ( virtualbox-5.1_5.1.0-108711~Debian~wheezy_amd64.deb):
# Get the latest from virtualbox.org (debian build)
dpkg -i virtualbox-4.3_4.3.4-91027~Debian~wheezy_amd64.deb
/etc/init.d/vboxdrv setup
modprobe vboxdrv
modinfo misc/vboxdrv.ko
This is what the installer throws:
root@NAS:/data/Virtualbox# /sbin/vboxconfig
/sbin/modprobe: invalid option -- 'c'
BusyBox v1.22.1 (Debian 1:1.22.0-4) multi-call binary.
Usage: modprobe [-alrqvsDb] MODULE [symbol=value]...
        -a      Load multiple MODULEs
        -l      List (MODULE is a pattern)
        -r      Remove MODULE (stacks) or do autoclean
        -q      Quiet
        -v      Verbose
        -s      Log to syslog
        -D      Show dependencies
        -b      Apply blacklist to module names too
vboxdrv.sh: Starting VirtualBox services.
vboxdrv.sh: Building VirtualBox kernel modules.
vboxdrv.sh: failed: modprobe vboxdrv failed. Please use 'dmesg' to find out why.
There were problems setting up VirtualBox.  To re-start the set-up process, run
  /sbin/vboxconfig
as root.
I get the modprobe error (this modprobe has no config dump option) but -failed to install vboxdrv? oh Really? - running modprobe -l I get this (all the complied kernel modules I built earlier):
root@NAS:/data/Virtualbox# modprobe -l
kernel/net/rfkill/rfkill.ko
kernel/net/netfilter/xt_nat.ko
kernel/net/netfilter/xt_conntrack.ko
kernel/net/netfilter/xt_addrtype.ko
kernel/net/netfilter/nfnetlink_queue.ko
kernel/net/netfilter/nfnetlink.ko
kernel/net/netfilter/nf_nat.ko
kernel/net/netfilter/nf_conntrack.ko
kernel/net/llc/llc.ko
kernel/net/ipv6/netfilter/nf_nat_masquerade_ipv6.ko
kernel/net/ipv6/netfilter/nf_nat_ipv6.ko
kernel/net/ipv6/netfilter/nf_defrag_ipv6.ko
kernel/net/ipv6/netfilter/nf_conntrack_ipv6.ko
kernel/net/ipv6/netfilter/ip6table_nat.ko
kernel/net/ipv6/netfilter/ip6table_filter.ko
kernel/net/ipv6/netfilter/ip6t_REJECT.ko
kernel/net/ipv6/netfilter/ip6t_MASQUERADE.ko
kernel/net/ipv6/netfilter/ip6_tables.ko
kernel/net/ipv4/netfilter/nf_nat_masquerade_ipv4.ko
kernel/net/ipv4/netfilter/nf_nat_ipv4.ko
kernel/net/ipv4/netfilter/nf_defrag_ipv4.ko
kernel/net/ipv4/netfilter/nf_conntrack_ipv4.ko
kernel/net/ipv4/netfilter/iptable_nat.ko
kernel/net/ipv4/netfilter/ipt_MASQUERADE.ko
kernel/net/bridge/bridge.ko
kernel/net/bridge/br_netfilter.ko
kernel/net/bluetooth/rfcomm/rfcomm.ko
kernel/net/bluetooth/bnep/bnep.ko
kernel/net/bluetooth/bluetooth.ko
kernel/net/802/stp.ko
kernel/net/802/psnap.ko
kernel/net/802/p8022.ko
kernel/kernel/configs.ko
kernel/fs/xfs/xfs.ko
kernel/fs/udf/udf.ko
kernel/fs/isofs/isofs.ko
kernel/drivers/usb/serial/usbserial.ko
kernel/drivers/usb/serial/pl2303.ko
kernel/drivers/usb/serial/ftdi_sio.ko
kernel/drivers/net/netconsole.ko
kernel/drivers/bluetooth/btusb.ko
kernel/drivers/bluetooth/btintel.ko
misc/vboxpci.ko
misc/vboxnetadp.ko
misc/vboxnetflt.ko
misc/vboxdrv.ko  <------
3rdparty/fs/ufsd/ufsd.ko
3rdparty/fs/ufsd/jnl.ko
dmesg complains:
 vboxdrv: disagrees about version of symbol module_layout
My srcs (both link to /data/Virtualbox/linux-4.1.21-197-x86_64 folder):
root@NAS:/data/Virtualbox# ls  /usr/src/
linux  linux-4.1.21-197-x86_64  vboxhost-5.1.0
and my uname info:
root@NAS:/data/Virtualbox# uname -r
4.1.21.x86_64.1
root@NAS:/data/Virtualbox# uname -a
Linux NAS 4.1.21.x86_64.1 #1 SMP Wed Jun 1 16:52:57 PDT 2016 x86_64 GNU/Linux
How can I get /sbin/vboxconfig to complete successfully?
  • enxer's avatar
    enxer
    Jul 23, 2016
    Sorry for not getting back to you until now - I saw your post but two active kids kept me busy from repling to these threads I've made.
    So I posted over in virtualbox and they reiterrated that my headers I built were not matching the running ones dispite the uname -r matching so I scraped everything, purged all modules and /usr/src and reviewed the orginal url  that this author got. I pulled a similar name down that matched my readynas os 6.5.1 and made them. Additionally I added the debian repository for virtualbox wheezy and I installed dkms which monitors for kernel header changes and compiles based on the kernel modules in the system. This got me to be able to install 4.3.8 which is happily running my Windows 7 32bit (I have atom processor (non-VT-x)) running Passwordstate for the house quite well.
    I hope my post helps someone out!
  • Trying the same thing here, and also having issues with module magics, though it's possibly something else I'm doing wrong.
    Out of interest, you've mentioned directory showing some additional number in it (197):
    The kernel dir I have out of the latest zip here:
    http://www.downloads.netgear.com/files/GPL/ReadyNASOS_V6.5.1_WW_src.zip
    just has a directory called:
    linux-4.1.21-x86_64
    With this kernel:
    head -4 /usr/src/linux/Makefile
     VERSION = 4
    PATCHLEVEL = 1
    SUBLEVEL = 21
    EXTRAVERSION =
    NAME = Series 4800
    Where'd you get the kernel sources with this extra number in the directory name?
    As for my lack of success, I'm not even able to
    sudo cp .config .config-old
    sudo cp arch/x86/configs/defconfig.x86 .config
    sudo make clean
    sudo make ARCH=x86_64
    sudo make modules_install ARCH=x86_64
    then
    sudo modprobe configs
    # modprobe: can't load module configs (kernel/kernel/configs.ko): invalid module format
    So I'm expecting anything the VirtualBox installer is trying to build will fail with mismatches also.
    sudo modinfo configs
    vermagic:       4.1.21.x86_64.1 SMP mod_unload modversions
    uname -r
    4.1.21.x86_64.1
    Seems... Odd to me.
    ReadyNAS 6.5.1
    RN516
    • powareverb's avatar
      powareverb
      Star
      Actually sorted this out in the end.
      On a hunch I'd got the wrong config, I had a look around and realised there's a special config file for the readynas setup...
      #Normal
      #sudo cp arch/x86/configs/defconfig.x86 .config
      #ReadyNAS
      sudo cp arch/x86/configs/readynas_defconfig .config
      Give this a shot and see if it works.  You may need to do a clean out first (of /lib/modules & kernel build dir).
      Have written up a full description based on a number of great forum posts.
      Kernel build:
      https://gist.github.com/powareverb/5a59e4e68c7e56033ba0998ef3b53b94
      VirtualBox build:
      TBC
      • enxer's avatar
        enxer
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello enxer,
    I suggest you contact the developer of this app you are trying to install. This is not listed and was not submitted to Netgear yet.
    Welcome to the community!
ProSupport for Business
