kevinffff's avatar
kevinffff
RN516 v 6.10.8 was factory reset, now uTorrent will not install
My RAID array was set to read-only after a succession of mains power failures (I suspect).  I have backups of everything including config files, so I am in the process of rebuilding after a factory r...
  • kevinffff's avatar
    kevinffff
    Sep 26, 2024
    I did as you said, WINSCP worked fine, files were copied, screenshot attached, but still the same error 😞
    UPDATE:  It's working!  I re-read the thread and realised I needed to connect over SSH and run "apt-get update" and now it is installed.
    Thank you so much!
ProSupport for Business
