kevinffff
Sep 26, 2024Aspirant
RN516 v 6.10.8 was factory reset, now uTorrent will not install
My RAID array was set to read-only after a succession of mains power failures (I suspect). I have backups of everything including config files, so I am in the process of rebuilding after a factory r...
- Sep 26, 2024
I did as you said, WINSCP worked fine, files were copied, screenshot attached, but still the same error đ
UPDATE: It's working! I re-read the thread and realised I needed to connect over SSH and run "apt-get update" and now it is installed.
Thank you so much!
kevinffff
Hi,
Thanks for this, I'm a novice with Linux but cut my teeth with CP/M and DOS, so I think I can manage to do this.
However, and this is probably a stupid question, but I don't understand this:
"Put these somewhere on your NAS using SMB, the GUI, or whatever. Then, from SSH, you simply need to copy them from where you put them to their proper place."
Where is the "proper place" for the files?
Thanks again.
Sep 26, 2024Guru - Experienced User
kevinffff wrote:Where is the "proper place" for the files?
The post actually does say
- /etc/apt/sources.list
- /etc/apt/apt.conf
So they both go into the /etc/apt/ folder
I haven't heard CP/M in a long time...
One possibility is to use WinSCP on the PC. You enable ssh on the NAS (as you would anyway) in system->services->ssh of the admin web ui. Make sure you enable password authentication. There is no need to download an ssh key file. BTW, if you are using the default admin password (e.g., password), you need to change it to something else.
You can then create a site entry in WinSCP for the NAS. Select "Tabs" at the top, and then "sites" (at the bottom of the pulldown). You'll then be able to open site manager. Set the protocol to SFTP, and the host name to the NAS IP address. The port should be defaulted to 22. Set the username to root, and set the password to your NAS admin password.
After saving this, click on "new tab", You'll be able to select the NAS site from there. You should see a long list of folders in the right pane of WinSCP, including etc. Navigate to /etc/apt, and then just drag the files into it.
- kevinffffSep 26, 2024Aspirant
Thank you so much!
