bmcdonald666's avatar
bmcdonald666
RND4000 v3 not powering on - migrate the drives
The solution to my problem detailed "First install a spare disk into the replacement NAS. Any SATA drive <= 2 TB will work for this. After the factory install completes, update the firmware in the re...
  • StephenB's avatar
    Jul 29, 2019
    bmcdonald666 wrote:
    By "migrate the drives" do you mean simply take out the one used to power-up and update the NAS and insert the 4 original drives with the data saved on them?
    Yes.  Do that with the NAS powered off.  Put each disk in the original bay (preserving the order) if you can.  Then power up.
ProSupport for Business
