tkernaghan
Oct 27, 2019Tutor
Slow internet speed
I have a ReadyNAS 312 and currently have the ReadyCloud app v1.19 running on my system. I am the only user of the ReadyNAS and use it for backup and storage. When the app is indexing or uploading files, my internet speeds go from 100/100 to 5/0 and I can't even load a Google search page. This only happens when the app is indexing or uploading, which happens a lot as I work throughout the day. I'm running Windows 10. I have no issues with internet speed if I'm not on the same network as the NAS. In other words, I'm better off working remotely which should not be the case. PLEASE, there has to be a solution to the app taking nearly 100% of my bandwidth. My device, Surface Pro, connects wirelessly. I've tested a wired connection and have the same issue.
When this problem occurs, is the surface able to reach the internet?
Is your ethernet speed gigabit or 100 megabit ("fast ethernet")?
How long does it typically take before the app completes and internet is restored?
One thing you could try is to reduce the priority of the process using Windows Task Manager, and see if that helps.
The app can connect directly to the NAS when you are working from home. When you are remote, the connection goes through Netgear Cloud servers, and they will throttle the bandwidth. So in general, the bandwidth peaks will be higher when you are home (though the application will complete more quickly).
Yes, my Surface is able to reach the internet but it takes a very long time to load a web page. It's like I'm on dial up.
Yes, my internet is Google Fiber 100 MB up and down.
Depending on how many files change, it can take several minutes to upload and complete. With files changing all the time, the app is in constant index & upload so it takes a very long time for my internet speed to return. Interestingly, I can stream TV on my Roku TV without any issues. It appears to only effect my Surface and it's ability to use bandwidth.
I don't know how to reduce the priority of the process using Windows Task Manager. I don't see that as an option when I open Task Manager.
tkernaghan wrote:
It appears to only effect my Surface and it's ability to use bandwidth. I don't know how to reduce the priority of the process using Windows Task Manager. I don't see that as an option when I open Task Manager.
It's either about network congestion or it's about the system load on the Surface. Let's figure out which before we start changing stuff.
If you bring up task manager, and click on the performance tab, you will see the CPU, Memory, Disk, and Network load for the machine.
Maybe keep that running while you are working, and give us some idea of what changes then the problem begins.
